1 - 20 of 45 Posts
2004 with 06 motor 200k Couple years ago standpipes and HPOP done. Started giving trouble upon warmup. After warm would not start. Once cooled down Ok. ICP at less than 500 when warm. Tried air test and couldn't verify leak. Changed IPR. Now no start. Won't build enough. Unplug ICP and get 1900 on crank but no start. Not sure what is next step. Using a OTC Genisys scanner. No codes.
What was the procedure for the air test you done?
How much torque on the IPR?
Truck, Van, Motorhome?
Disconnecting the ICP caused the PCM to use a default number -- that number is not real
best to read voltage from the ICP and use the pressure reading to correlate with the voltage
So the 1900 is computer default number? ICP voltage .22V and of course 85 %. Crank crap out of it and will hit 2000 and voltage 3.5 and percentage goes to 53. Circuit must be operational and must have good old leak as it won't maintain 500.
Actually an inferred number based on what the PCM expects for the current conditions -- so would not "always" be 1900
it is part of the strategy to "get you home" in case of a sensor failure
You had the thread adapter or just stick a rubber tip in the port?
How much pressure?
I was asking you about the torque - how tight did you put it?
IPR torqued. I made
my own adapter and used 110 lbs.
you need to loosen the valve, it can bind the poppet from the threads distorting the bore -- the valve only needs to be tight enough to keep from backing out from vibration -- about 16 pounds
the oring is what does the seal
The socket I got came from Autozone for $8 -- pretty much just a deep well with a split up the side for the solenoid connector
So, ...when you apply power to the IPR the air sounds stops?
Does the terminals in the IPR connector look like they are gripping the pins in the IPR?
the percentage is just a commanded value generated by the PCM -- the only real way the PCM "knows" that there is any pressure from the HPOP is by the voltage reading from the ICP
ForScan would be my choice of apps to troubleshoot -- it reads Ford very well and can operate the IPR
so, monitoring the IPC voltage and then changing the IPR value would let you know if the PCM can actually make the changes or not
I suppose you could use a jumper pigtail on the IPR and monitor the ICP voltage -- that would test the HPOP system, but not the electrical side
Discussion Starter · #15 ·
The IPR is controlled by Pulse Width Modulation -- basically 12 volts at 400 MHz but differing "on" - "off" times to control the pintle position
ForScan uses the PCM so you get the benefit of the PWM control
I dont think a variable power supply will give a variable operation of the IPR, but worth a try to see -- post your results
A variable frequency supply may get close, but really a PWM controller is best
you can put straight 12 volts for a few minutes, than will fully close the IPR and drive the pressure to the max -- 4000 psi
Any one of those methods should give valuable intel into whether the high pressure system can build pressure
Discussion Starter · #18 ·
So theory is if IPR is latched it should build pressure fast and hold. If not has HP leak. If not has a computer/wiring issue. Do know where 12 supply pin is on computer> Know #2 yellow/red is ground. Just want to do continuity check on IPR and harness.
I know where it is on the diagram, but those do not often follow reality
The "ground" is PWM controlled by the PCM -- the hot is constant
IPR, EGR, GPCM, and PCM (input #46) share the same hot wire -- from the PCM power relay
1 - 20 of 45 Posts
