1 - 2 of 2 Posts
Early '99 F350 7.3l
Long story short I burnt the insulation off some wires putting a custom rear bumper on. They shorted out after making contact with each other and blew fuses. I fixed wires, replaced relay and fuses in drivers side fuse panel, and even took radio out and replaced the flasher. I still have no signals, hazards, or brake lights! This is my only vehicle and I need it to work right and can't afford a shop bill or have it in shop for a long time... Is there something I'm missing??? Could something else be fried?? Please help
FYI when I turn either signal on or hazard on there is no click from the flasher or indication light on panel
I know this is over a month old but-look at multifunction switch on steering column. WD40 in 4way button and on/off 30 times sometimes can revive it for a while-else it has to be replaced.
1 - 2 of 2 Posts
