I had 14 psi at the FPR so I installed a brand new fuel filter housing complete with new FPR, drain valve, vacuum switch. (the whole unit came with everything including fittings) I installed a new gauge at the shraeder valve (3rd one) and I got 12 psi at idle and took it for a 15 mile spin and the gauge read 5 psi. no leaks, no fuel in valley. This truck runs good, idles good, Kind of feels slugish when you get on it like passing someone. I drained the fuel bowl housing, not a drop of fuel in it or the filter and started it, it turned about one and a half turns and started. I don`t see how that could be a bad fuel pump but can`t understand why there is only 5 to 10 psi pressure at the FPR. Somethings wrong and I have a trip to make and would like to find it here instead of on the road. Any sugestions appreciated TIA
