1 - 9 of 9 Posts
i have output from the switch but no power to the fuses
is there any where i can get a wiring diagram for the headlights
No low beams
Did you figure out the problem. I have no low beams. High beams work fine.
all fuses are fine. any help would be great
I did it was a loose connection on the back of the fuse panel. Good luck
SSB or Sparky;
Care to explain your solutions? My brights been out for a while, but i dont use them much so I havent messed with em.
Thanks.
shhhhh, can you hear it?
just get a multimeter and start chasing wires until you find a dead spot.buy a haynes manual from auto zone they have the wiring diagram in them.i presonally have one for every vehicle i own and when i get rid of one i leave it in the car to go with it for the next owner.
Hey Harley,
Open the stearing colum and at the base of the turn signal is a switch. There is a 6 prong plug that was loose going into the switch. All I had to do was push it in tight and presto, my low beams are working again.
1 - 9 of 9 Posts
