Abit of a giving back to the community for those still on the fence about tuning their truck. I have never used EZ Lynk before and am a moderate mechanic.
TL;DR - Despite abysmal instructions and inconsistent data on their website, I highly recommend No Limit and this setup. EZ-Lynk was impressively simple and takes about an hour in the garage. Get the shift-on-the-fly option. EGR Bypass is pending. Android app and iOS app are both available (No Limit website is out of date)
Background:
I have a 2014 F-250 w/ 50k miles CCSB. It's the family beach/road trip vehicle with the heaviest load being some luggage and paddleboards. I wanted a truck with a lot of interior room, which the F-250 has in spades, while the power and fuel economy made the Powerstroke an easy decision. The EGR was replaced under warranty twice: once at 15k miles, and again at 45k miles. I personally don't mind the DPF and EGR...until it fails. With the EGR needing replaced 5k miles ago, I started looking into how to permantently solve it as my warranty was coming up. The EZ-Lynk (and EGR Bypass) are my solution; releasing untapped torque and correct the flaccid-stock-shifting were bonuses.
The EZ-Lynk and SOTF is installed. I haven't installed the EGR Bypass (yet) as I'm still researching the procedure.
Review:
I got the EZ Lynk with Tyrant Tuning, SOTF switch, and EGR Bypass from No Limit Tuning. After a lot of research on different options and tuners and chose the EZ Lynk for it's improved future-compatibility, data logging, gauge monitoring, and being able to move to a new vehicle (if I wanted to). I called a few different dealers and was impressed with No Limits' responses and patience with my noob questions (what's the difference between the bypass and block? Why would I want one over the other?). Not only are they very active on the forums, but I actually spoke to Jeremy; THE guy who I've been reading about. All of the companies I spoke to were well versed and choosing one was a hard decision, but I choose No Limit mostly due to their activity on the forums.
Unboxing:
The EZ Lynk, switch, and EGR arrived on time via 3-day UPS. It was packaged well (BTW: The 'No Limit' packaging tape was AWESOME.). The switch included a wire loom (impressive) and a sticker w/ 1-5 indicator for the switch (impressive again), and the EGR block is high-quality aluminum that's been CNC-ed. It was obvious this wasn't some *******-rig job; the packaging tape, the loom, and switch sticker, clearly announced a thorough effort and work to deliver a quality product.
Installing EZ Lynk:
The EZ Lynk hooks up to the OBD2 port and is paired with a mobile app called "Auto Agent" available on Android and iOS. Connectivity between the EZ Lynk and the App is down over WiFi, which is a nice addition so you don't lose your Bluetooth connection to the truck. Be sure to disable your Bluetooth when writing a tune to the ECU; otherwise you may auto-connect to your radio, play music and adversely affect the Auto Agent process. You'll see a lot of options for ECU profiles, with little-to-no directions on which one to download. If you get the same setup I did, you'll want the 13-14-TD-SOTF-NON-VGT-NEW-SWITCH (40-175hp) Updated 12/17. It took about 10-15 minutes to download the tune into the truck once is started "installing".
There's no security on the Wi-Fi broadcast and no authentication on the app. While there is value in real-time monitoring your vitals via the app, I question it's value when considering the security risk. Once I updated the tune, I disconnected the EZ Lynk and left it in my glove box incase I need it in the future. If I do tow with it, I'll hook it up temporarily to monitor my EGT and then unhook it when done.
Installing the switch:
The instructions are atrocious. Getting the wires through the firewall was explained well and had a couple of pictures, but the instructions to find the Charge Air Temp Sensor were two black-and-white picture, bad angles, and a very light arrow. I've attached two better pictures showing the placement. There were no suggestions nor instructions on switch placement; you're left more-or-less on your own. Not being a fan of drilling a hole in the dash of my $50k truck, I opted to use one of my cigarette lighters, a washer painted black, and a piece of cheap sheet metal on the back to hold the switch (added a picture as well). I expected color pictures for my $1500 investment.
EGR Bypass (Not done):
The Achilles Heel of this setup are the instructions, and the EGR bypass is the most egregious example. There are 31 steps for the entire procedure and the entire thing barely takes up a page an a half. Most of the instructions are single sentences, with a couple of small black and white pictures (2"x2") on a separate page. I'll be doing more research before I tackle this. I was disappointed as the EGR Bypass was the primary reason I bought the setup, but I'm confident that it'll be worth it once I've done the homework to figure out how to install it.
Tune Review:
My first impression: WOW, what a big difference. The options are potent and easily discernible, while the transmission shifts fantastic. The hobbled-wet-noodle feeling is gone; now the truck pulls, pulls, then pulls some more. Step 2 or 3 will probably be my daily-tune, with step 4 & 5 there for a quick bit of fun. I've only put a dozen miles during test drives and will be updating as I put some more time on it.
Bottom Line:
This is a great setup that's well thought-out and worth the investment. The only demerits are the poor instructions and inconsistent website; the instructions to build an IKEA side table are more detailed than the EGR bypass. But No Limit makes up for it with it's fantastic customer service, quality parts, and attention to other details (wire looms, stickers, etc.) Overall 4-out-of-5 stars.
Background:
Review:
Unboxing:
Installing EZ Lynk:
Tune Review:
Bottom Line:
