Ok, I'm new here. I searched for about 30 minutes and found a few threads that were similar, but not exact to my issue.
I just put in AUXBEAM H13 LED headlights and, LED fog lights in my 2006 F-250 Super Duty. I do not have a problem with flickering, but the issue I have is thus:
When I am running my lights, on Low beam with the fog lights on, the Fog lights and low beams work. But when I pull the combination switch towards me, which should activate my high/low beams simultaneously, what happens is that the Fog lights go off, and the low beams stay on, but the high beams don't activate. I can activate my high beams by pushing the combination switch forward, into the normal "high beams on" position, and the low beams turn off (which should happen) and Fog lights go off.
Can someone please explain to me how I set things up so that when I flash my brights by pulling the combination switch, the low/high beams activate together, and how to get my fog lights to illuminate while the bright lights are on?
Thanks, and sorry for the naivete...
