1 - 7 of 7 Posts
I accidentally broke the yellow clip on the fuel filter supply line today. Only the top of the clip broke off. The supply line remains tight, the system primed, and no leaks. The clip no longer appears as original, but seems to function. I looked for a replacement clip, but most results are repair systems that replace the entire 90 degree elbow plastic assembly and a portion of the line. So, my questions are:
1. Should I be concerned at this time?
2. Does anyone have the part number just for the yellow clip. (I’m both lazy and a cheapskate)
I am actually in between jobs at the moment
I start a new job on Monday after moving to Washington state
However. I don't believe that those clips are available separately
Sent from my SM-G960U using Tapatalk
Reactions: ZMANN and DTMurrell
I did find a box of fuel line clips online, but it’s very generic and doesn’t specify any makes/models. The repair kit that includes a new elbow, hose and clip is $25-$45, so not awful, but I hate to go to that much trouble over a cheap plastic clip.
Ford service department carries the clips, I have replaced mine on the fuel tank same style clips.
Sent from my Pixel 3 XL using Tapatalk
1 - 7 of 7 Posts
