1 - 11 of 11 Posts
My new to me 2017 XLT has the "plain" chrome bumper with no factory recess for fog lights... Short of replacing the bumper (my "CFO" will not likely approve the spend request) anybody else with this bumper found a nice looking aftermarket fog light solution?
I do not have uplifter switches and the headlight switch does not have the pull out (naturally). I do not really mind the thought of figuring out how to pull a wire/s and mount a new switch in the cab though. I've got a buddy that used to install lights and radios in vehicles and I can get him to help me out with that part if needed.
I miss my fog lights!
I've seen some nice light bars out there, not sure I want them mounted where it would block airflow though, maybe I'm just a worry wort, but I tow a 9,300# camper and do not want to risk overheating by adding something that blocks too much air.
And...
I'm in Ohio and required to have a front plate. I had a thought of modifying that front plate bracket to be able to hang lights off it or mount on the sides... But - I don't want it to look janky... I'm sort of stuck in analysis mode...
I'm really struggling with my imagination trying to come up with a idea that will look decent and be functional. Anybody else with this style bumper added lights up front and want to share ideas with me?
cut the black plastic piece out, get led cube lights. Throw them in the iJDM brackets or make your own and wire them up. They will blind people unless you get floods only. I got straight spots for my factory replacement and they are brighter than stock headlights
That's what I was thinking at first, and I've been looking here and google image search... I'm starting to wonder if I'm the only one with this bumper... I Do not have anything to cut out where factory lights would go... I could maybe use or relocate the plate...
I have honestly not seen that style bumper, all the 2017 work trucks there are at my shop even have the spots for them but are just covered by black slotted plastic. You could just throw them in next to your license plate, like the 6.0s have it. Other than that your cutting the bumper or getting one from a higher trim level.
Discussion Starter · #5 · (Edited)
OK - Did some more searching and I think I see what you are talking about the 6.0s... That looks doable. Thank you!
would a 2018 bumper fit on a 2017? I am going to upgrade soon and my stock bumper has the foglights. Just straining the brain here.
I have the same bumper, also 2017 XLT. Thought about fog lights down the road. Interested to see how it turns out for you.
Discussion Starter · #10 ·
Sadly, I've just discovered that my house down at the farm has a leak in its roof... :( that's got a hold on any new toys for me for awhile.
yeah leaky roofs take priority
1 - 11 of 11 Posts
