2006 6.0 Powerstroke
I replaced the turbo, ( the bearing was shot, no boost whatsoever. the truck was running before i worked on it.)
After fininshing the install of a remanufactured turbo, the truck will crank with no attempt to run.
(the batteries were left disconnected for a few days during the turbo install)
Codes
P1000 ODDTCs On-Board Diagnostic (OBD) Systems Readiness Test Not Complete
U0105 ODDTCs Lost Communication With FICM
U0306 ODDTCs Software Incompatibility With FICM
I called a ford trained mechanic to look at it and he said it needs a new FICM.
I'm not 100% confident its just a bad FICM, bcz there seems to be an electrical short... the batteries slowly drain and there is a small spark when you connect cables to the battery terminals. (in particular the smaller positive cable on drivers side battery has a spark)
The truck started fine before i changed out the turbo. I have owned it for 4 months, generally it ran good until the turbo failed. It did have some 'gremlins' such as tbc fault, the tach and speedometer sometimes would read low or go to zero while driving, A/C does not work..)
Obviously it must be related to the FICM that it wont start, but what caused it to fail
I dont want to replace the FICM, and just have it burn out again.
or maybe its fine and not getting power?
How can i diagnose this problem?
Thx
Codes
Thx
