1 - 5 of 5 Posts
My 2003 f250 6.0l 4wd is not cranking unless I jump the starter. Once running transmission feels stuck in 3rd. Tow/hual switch doesn't work and can not get it to engage in 4wd low. There are 9 codes. I will post those once I get home. But the list of disribtion as follows;
#3 injector contribution/balance
Fan circuit low
Lost communication with ficm(brand new 6phase 58 volt from bpd)
Lost communication with tcm
Egr low flow detected( exhaust manifold leak)
Vehicle voltage low(15.8 engine running)
Map sensor code
Can't remember last two.
Truck is stock with exception of ficm and kn filter system.
Any help would be much appreciated.
Already tried unplugging fan sensor didn't change a thing.
One of the codes was #1 glow plug circuit open. Like I said I will post exact codes in a couple hours.
Discussion Starter #2
I left out that the trams temp gauge no longer moves at all.
Codes. Are
Poo6a
P0269
B1869
B1892
These are the ones that came back after a 15 mile drive to my office and back
okay the got the truck to start and shify by cleaning pcm conections, but did not know how to diagnose misfire with bpd ficm on the truck. here are my codes.
p0269,p0401,p0460,p0603,p0671,p006a.
so is my truck %^^& or what?
The truck is misfiring and clear codes and P0269 comes back immediately. One shop told me that number 3 is dead completely along with 1&8 going south. Any ideas????????
1 - 5 of 5 Posts
