Hey guys I’m new to powerstrokes so bare with me if I’m missing something obvious.
I just picked up a 06 F250, it started and ran fine for a week then the temps dropped down to 20f and when I went out to start it I got no crank. Left for work and ignored it until the next day when it was 45f and the truck started right up. Well now we had temps dip down to 3f and again no crank at all. Plugged it in and went out about 4 hours later and the truck started.
I just took it down and had the batteries and alternator checked and both were fine. The batteries are less than a year old. Prior to me buying it the injectors, icp, glow plugs, and wire harness were all replaced buy a shop. I had a bad oil pressure switch that I replaced and the only code is a EBPS (p0472). I tried cleaning it but I get the same code so I’m waiting for a new motorcraft sensor to arrive. I can’t see how that would cause the no crank so I’m at a loss. I checked the ficm and it was 47.9 key on, and 47.9-48.1 running. Any thoughts on which direction to start looking?
