Okay everyone, I am in need of your expertise. I apologize upfront for the lengthy explanation below.
A couple days ago I tried to start my 02' F-250 7.3 with an automatic transmission and got no crank and no start. It sat for 5 days before this without being started and the temperatures here have been between 20-30 degrees Fahrenheit. First thing I did was plug it in and tried to start it 4 hours after being plugged in. Still, no crank no start. I also tested the voltage across the GPR and all was good. When I turned the key to start it, the truck clicked rapidly and the dash lights would flicker on and off. This led me to believe it may be the batteries (I have two 6 month old Interstate Megatron batteries). I attempted a jump start and that didn't change anything. After that I had both batteries tested and they are in good working order. Before hooking up the cables, I cleaned the terminals and cable clamps to ensure that wasn't the issue. I also tried starting the truck in neutral, still nothing. I checked all the fuses under the dash as well, all fuses were good. The next thing I tested was the starter. Since the 02' does not have the solenoid on the passenger side fender, I pulled the little circular harness and ran a lead from the positive terminal on the battery to the male end of the harness and it did not turn the starter. This alone makes me believe it is a good chance it is the starter, but the clicking and flashing dash lights have me concerned it may be another issue. Would a bad starter/starter solenoid cause rapid clicking and flickering dash lights? Any thoughts or tips on this would be greatly appreciated! Thanks!
