hello I Drive a 2005 F 350 6 liter diesel with no check engine light my throttle will sometimes just idle no matter how hard I pressed the throttle then out of the blue will take off motor does not die motor does not sputter motor just doesn't go sometimes it will sometimes it won't sometimes at stop lights sometimes driving down the freeway not left me stranded only lasts about a minute or two and I have not been able to resolve this issue I've check the threads I have found similar issues but nothing with no code and nothing with my exact truck all help is greatly appreciated thanks
Discussion Starter #2
update
Only happened once since my last post but throttle was working if I shifted into neutral. Just not a single response in drive. And I would love a little help. ANYBODY?
Also took to ford and had reflash update and they did scan said no problem found. Has done it once sence then. Only last about 30.seconds. no throttle. Then wait wait and I am driving like normal. Thanks for your help.
