My brakes started acting weird last week.
Last time I used the truck (99 f350 crewcab dually), when I pushed the brakes they were on and off. You pushed the pedal, but the brakes were acting just like if you were pushing and releasing the pedal 3-4 time per second...
Did'nt drive the truck for a week, and this morning, no Brakes at all... Pedal is on the floor, and even if you pump the brakes, it is not building any pressure...it will come back up ,but very slowly.
Power steering is not really hard to turn, maybe a little...
Oh , and I got no leaks anywhere...
Any ideas??
Is your ABS light on? This sound like my brakes when the ABS activates. Which isn't often, only in the winter when the snowbirds are in town.
i just went through the same thing and i had a pin hole in my line. Check and see if you have any fluid left and if you dnt check for leaks. Should be able to see pretty clearly the area its leaking from.
Its steel line all the way back to the rear and if it rubs on the frame or somethin it might have finaly ware through. just sumtin to check
