1 - 12 of 12 Posts
Ok, drove the truck home from work last night and everything was good, get in it this morning g and i dont have any boost. checked for codes but it is showing nothing. anyone have any idea what it could be.
Yeah. No power because i have no boost. I need t get my ficm done. Could this have something to do with it.
I am not getting the normal turbo whistle from it. Could it be the vgt solenoid or ebp sensor
Sent from my DROID RAZR using AutoGuide.Com Free App
Bump
Everything you mentioed is a possibility but each will useually throw a code of some kind.
What were you reading the code with?
Its an inovva code scanner. Its for obd2. And it links with the computer.
I ran a koer test with it and it is showing an ebp code and a couple of egr codes and also a ficm code but i knew about that one.
Pull the ebp sensor and clean the sensor and tube pull the egr and clean it as well see if things improve. You also may need to clean your turbo.
ok will try that, i am getting ready to park it and do the top end rebuild with studs, egr delete, new oil cooler. just waiting for the funds to hit the bank.
Any resolution with the "no boost"? I have the same deal. I notice my engine light on then shortly there after my boost gauge is not moving. Doesn't feel like there is boost. I need to get this code read....
Trucks at the Docs getting checked out. :please:
1 - 12 of 12 Posts
