1 - 5 of 5 Posts
Help please my 6.4 I bought a mini maxx yesterday plugged it in ran it with dpf filter on and mild tune setting . Now I can’t build boost and ebp sensor code came up is that why I can’t build boost ? I couldn’t find any damage on any of the boots so idk
I'm not sure I understand his post completely - however, the EBP sensor has all kinds of negative effects is it is inop. . . Look for your EBP sensor. Stock is on the driver side well visible and attached to the valve cover. Replace it - clear fault codes thrown and try again. An inop EPB sensor most likely. However, blown up-pipe has a very distinctive sound of escaping exhaust under pressure.
DPF deleted? If not - do so very soon or buy another engine that costs more than you paid for your truck. ??
My Turbo had quit working do to the passenger exhaust up pipe blew this in turn had no exhaust pressure top turn the turbo over. I had done the full delete a few months before that up pipe blew. 80,000 miles
on the truck.
1 - 5 of 5 Posts
