1 - 8 of 8 Posts
Hi to all
I just purchased my first powerstroke, its an early 99, born 3/98. It is bone stock. I'm looking upgrade the exhaust. I'm thinking that 4" turbo back will to the job. Next, I would like to know the opinions on the high flow turbine outlet, worth the trouble or not? Also gutting pedistal yes or no? Would I notice a difference if I did all at once? Thanks for looking and any advise.
Bryan
If it were me, depending on how extreme I planned to mod it in the future. I would spend about $50 to have a muffler shop cut out the cat and muffler and weld in straight pipes and save my money for gauges and a chip, I’d also spend $40 on the DIY intake as quickly as possible.
If after future mods I started having egt problems then I might do the 4” Down pipe and 4” or 5” exhaust.
what is the part# for the diy intake.
6637. ordered mine from fleet filter and arrived very quickly. i went with a budget kit 5" exhaust from farmboysdiesel as well. great kit. and even better price. the install was the easiest part ive ever installed on any car. i barely even had to move the spare tire to get it to fit.
I use the Baldwin PA2818
PART NUMBER: PA2818
Descriptions : Air Element
Replaces : Donaldson ECB085011
O.D. : 8 1/2 (215.9)
I.D. : 4 (101.6) One End
Length : 12 3/8 (314.3)
Here is a list of cross over numbers for most major manufactures for the same filter from the Baldwin website. You can also go to the Baldwin website and put your zip in to find local dealers.
ACDELCO A1474C
AIR REFINER ARM08-5011
BALDWIN FILTERS PA2818
BIG A 94637
CATERPILLAR 3I0003
CARQUEST 88637
CUMMINS 2912986
CUMMINS 3912020
DONALDSON B085011 H
DONALDSON ECBO85011 H
DONALDSON ECB085011 H
FLEETGUARD AH1141
FLEETRITE AHR81141
FRAM CA6818
GFF AF359214
GENERAL MOTORS CORP. 25177209
HASTINGS PREMIUM FILTERS AF2329
HERCULES B085008
KRALINATOR LA1458
LUBER-FINER LAF2533
NAPA GOLD 6637
SCHUPP SL12903
WIX 46637
WIX 546637
WOODGATE WGA1138
Thanks for the help.
Just bought my first diesel as well. It is a 2003 F250 and also on a budget. I purchased a diablo tuner and changed out the factory filter. What I did for now on the exhaust was to cut out the muffler. My truck is still under factory warranty, so I just chose to make one change. I hope that it doesn't mess up the truck. The tuner recommends a 4"turbo back exhaust when on performance, but I am going to try to get a EGT gauge set up so I won't mess nothing up while towing a travel trailer.
1 - 8 of 8 Posts
