1 - 8 of 8 Posts
Hello everyone. Im going to keep this short and sweet. I recently purchased a used 2004 f-350 fx4 crew cab and Ive never owned a diesel nevermind a powerstroke. I do have years of turning wrenchs and experience with turbos on gasoline engines. I just want to know what to look out for and what is must be maintained. I am aware of head studs and egr delete.. my truck had the delete done already. I am also aware of the 2nd fuel filter below the drivers cab. Im concerned about programming but I want better mpgs. is it ok to program with stock head bolts? my truck has 340,000Km. thanks ps is it important to use fuel conditioner if im using premium diesel?
Welcome. Check out the stickies here in the General 6.0L Discussion area. Everything you are asking for is right there.
Welcome aboard!!!!
Welcome aboard!!!!
Thanks alot everyone ive been doing lots of reading and the problem is there is so much contradicting things being said about what to do with the 6.0 powerstroke.
I read some where about number 8 injector being different and causing knock on cold start ups? whats the about because i hear a bit of it. can it damage anything?
any tips for better mpgs I used shell vpower diesel here in alberta and noticed much better range than using petro canada ulsd. Im affraid to put a tuner on my truck because its our only daily driver right now.
Anyone used bd diesel tuners? I can get my hands on one for $50 but everyone says to use SCT. soooo much to learn lol.
For a truck with an EGR delete, you need an SCT with custom tunes, also make sure that the butterfly in the throttle body under the intake elbow is removed. This is part of the EGR system and will close to try to pull exhaust in from the (now deleted) EGR, causing restriction.
Discussion Starter · #8 ·
any pictures or precedures on how and where to remove the butterfly?
1 - 8 of 8 Posts
