81 - 84 of 84 Posts
That’s awesome! Glad you got it running! Injector cups don’t seem too difficult to install. This is a kit from Riffraff. After you use it I’m sure you could sell it for a good chunk of change. I don’t know what a shop charges in labor for a cup install. Here’s a good video on install.
https://m.youtube.com/watch?v=Ck1hQEunB-o
Here is the kit
https://www.riffraffdiesel.com/riffraff-diesel-7-3l-injector-cup-sleeve-tool-set/
As far as injectors go, I remember reading that Swamps has an amazing warranty on theirs. The thread in this link is an amazing video on understanding and choosing injectors.
https://www.powerstroke.org/#/topics/1348761
Swamps has a 5yr 200,000 mile warranty on their injectors.
https://swampsdiesel.com/products/160cc-single-shot-injectors-stage2-single-shot/
Keep us posted man!
Discussion Starter #82
I'll likely be ordering the injectors, cups, and tool from Rosewood diesel. A basic set rebuild from them starts at $500. Their premium rebuild is $1100. I'll go ahead and get the full premium rebuild.
Unfortunately - I'm in the agriculture industry (beekeeper) - and flow (nectar and $$) in my world starts up in early spring - so that's when the cash for the parts will be available.
Until then - I'm going to use the Stiction Eliminator by HotShot to see if that can help until I can get a full and proper injector and cup replacement done.
Over the winter I'll also address my codes that keep my SES light on as well. I'll do that in a fresh thread If I can't figure them out with the forum search tool. (i.e. I have a constant MAP low code - P0107 - and have changed my MAP sensor - but the code still is in place. It could be that I need to actually drive the truck for x number of miles for it to go away - or there svould be something other than the MAP sensor that is actually wrong... (i.e. does a 2001 F250 have a baro. sensor separate from the MAP sensor? )
Then there's the GEM code: B1352 to figure out as well.
Discussion Starter #83
Just an update. Last week I warmed the engine (again - starting with brake cleaner as my "starter fluid") - then changed the oil, and added 2 quarts of Stiction Eliminator by Hotshot. Then ran at idle for about 45-minutes. It sure sounded good after that oil change, and the cleaning additive in the oil. Let it cool off overnight. - Hoping that it would start right up - but no dice (Life can't be THAT easy, eh?). Brake cleaner used once again as a starter fluid the next morning.
I also noticed a few things after running the engine:
-Oil drips on the pavement - near front of engine - I suspect from the oil cooler.
-Oil drips from rear. Upon investigation, the valley has a puddle sitting up there - and I found NO oil leaking from the (3) HPOP connectors - and the puddle was near the pedestal below the turbo. Ill plan on new pedestal/turbo seals as well.
So - I'm planning other work to be done when I change the injectors/cups in the spring. Are there any other areas that would be suspect for oil leaks that I haven't already mentioned above?
I'll also be fixing the parking brake this next month - so I can get the truck inspected/registered. And thusly start driving it around town a bit. Would I expect to see any or much cleaning of the HPOP side of the injectors at idle with the Stiction Eliminator? OR do I need to run the truck for it to be most effective (if it helps at all, anyway?)
No reason to change out the injector cups unless there is one or more leaking coolant ...save you money for other things.
I have read a couple of posts about using a shim kit to fix the worn injector poppets, stiction is not much of a 7.3 thing but worn poppets is.
Curious if when the engine is idling, is there much blowby coming out of the oil filler with the cap off?
81 - 84 of 84 Posts
