1 - 16 of 16 Posts
Hi there! I'm new to forum and trying to get up to speed. I have seen many abbreviated terms used and would like to have a list of or a link to what some of the more common ones mean. So far, OBS is driving me nuts. My best guess is Otherwise Bone Stock, but a search hasn't yielded the result, as of yet. Thanks for any help in advance. I look forward to a lot of good info and advise in the future.
Shaking the Bush Boss
IIRC.... If I Recall Correctly
IMO.... In My Opinion
DIY ... Do It Yourself
only ones I can come up with, unless your needing the names for the valves and switches....
IPR .... Injector Pressure Regulator
IDM... Injector Control Module
Sticks..Injectors
HPOP - High Pressure Oil Pump
EGT - Exhuast Gas Tempurature
EBPV - Exhaust Back Pressure Valve
EGR - Exhaust Gas Recirculator - 6.0L
DPF - Diesel Particulate Filter - 6.4L
UVCH - Under Valve Cover Harness
VCG - Valve Cover Gasket
FPR - Fuel Pressure regulater
CPS / CMP - Cam Position Sensor
IPR - Injection Pressure Regulater
ICP - Injection Control Pressure sensor
VVT / VGT - Variable Vane Turbo / Variable Geometry Turbo (sliding nozzle)
HEUI - Hydraulically actuated, Electronic controlled, Unit, Injector
PCM - Powertrain Control Module
IDM - Injector Drive Module
APS - Accelerator Postion Sensor, commonly called a TPS
MAP - Manifold Absolute Pressure sensor
EOT - Engine Oil Temperature sensor
IAT - Intake Air Temerature
BARO - Barometric pressure sensor
LPOP - low pressure oil pump aka lube pump
DTC - Diagnostic Trouble Code
ECT - engine coolant temp
WOT - wide open throttle
AIH - air intake heater
TFT - transmission fluid temp
CCSB - Crew Cab Short box
CCLB - Crew Cab Long Box
RCSB - Regular Cab Short Box
RCLB Regular Cab Long Box
OBS - Old Body Style
FICM - Fuel Injection Control Module
PSD - Power Stroke Diesel
DIT - Direct Injection Turbo
IDI - Indirect Injection
CTD - Cummins turbo diesel
T444E - International/Navistar's name for the 7.3
VT365 - International/Navistar's name for the 6.0
TCM - transmission control module
IC - intercooler
TC - torque converter
SD - Super Duty
I know there are more
Welcome to Powerstroke.org
:welcome1::welcome2::welcome1::welcome2::welcome1::welcome2::welcome1:​
Other vehicle is an F250
:welcome1:
Welcome to the ORG!
Tennessee Powerstrokes
Welcome to the Addiction um I mean Org!
WOW welcome - this is the first intro thread that had enough info in it to deserve sticky status. Dude, you deserve a medal.
a known holder of grudges
:icon_ford: :icon_ford: :ORG welcome: :ORG welcome: :ORG welcome: :icon_ford: :icon_ford:
1 - 16 of 16 Posts
