1 - 9 of 9 Posts
Hi folks new to ps.org.Seems like a great site!And i figured i would jump right into it!
Just bought an 08 lariat ccsb and I want to level it.
Was thinkng of the ready lift or the newton kit.
Any preferences between the two.
Also I had a 2001 supercab with a 4' kit with 35x13.50x18 cooper stt on 9" 2crave nx2 wheels and they rubbed at full lock to the left.
I really want to go with the same same setup.But i'm not sure if it will work with a 2.5" leveling kit.
Ready lift says up to 37x12.50 but im not sure about that.
Any suggestions or thoughts would be greatly appreciated.
Thanks in advance
Thanks cary I am not looking to go with 37's. I w
9" wheels.But i worry about rubbing with the wider 13.50 tire on a 2.5 level.My backspace choices are -12 or 12 offset on these specific wheels.
ant to go with 35X13.50 X 18 with Thanks again roy381
You could also check out the Daystar brand of front leveling kits. They use a 2.5" poly spacer on top of the factory coil spring. I have them on my truck and they ride really well. I use to have a lift spring and it was wound so tight and rode horribly.
1 - 9 of 9 Posts
