I have the regular SRL and I hit boost pressures of 35 psi max. I have a plate over where the egr valve goes. I am just going to plug it in and leave it hang there if i still have the valve. I dont see why there would be a problem with not having the valve plugged in because i had it like that with my idp tunes and hit 30 psi. tune hauls butt tho with hitting that high of boostJust put your EGR valve back in the factory position, plugged in.
And the SRL++ is only for trucks that CANNOT hit 30 PSI of boost on the SRL+, if your truck hits 30 on the SRL+, the SRL++ will actually run slower.
It also depends on the strategy in your truck. I read somewhere else that ford made a newer tune in trying to stop the elimination of the egr system. my vxap2 does not vane cycle or that and i believe that is a newer crappier stratInteresting. My 05 without the egr valve and Matt's tune has no CEL and the turbo still cycles. My temps never get high enough to kick the fan on.
When you say they were off what do you mean? The truck ran hot? Lots of turbo lag?yup and matts completely right, my vgt cycle and fans were off on my 05 with the egr turned off in tuning, i had to buy a spare egr valve to plug in to get rid of my CEL, and my truck went back to normal. I just plugged it in and left it on top of the engine, i still have my delete plate on there
When is the last time you had your truck reflashed at the dealer? If that is an older strategy it probably will not do the vanes sweep. I didnt ask matt to do it in the tuning. it is in my stock vxap2 strat and carries over into my custom tune only if i have my egr valve plugged in. vanes will not sweep without egr valve being plugged inwill vxbc9n8 cycle the vanes at idle. I have matts tunes and it doesnt. Is it something you ask for in tuning?
