Looking to install a oem remote start on 2016 XLT. I have seen it is an easy add but can't seem to find where the antenna plugs into the tpms module. Truck has the hood switch and remote keyless entry. Does anyone know why I can't find where to plug the antenna?
2016 F250 CCSB 6.7 4x4
On a 2016 its up in the headliner, near where the drivers side sun visor mounts.
Remove the drivers side A-pillar handle, the drivers sunvisor, and also the overhead console for the sunroof switches. That should give you enough play to pull the headliner down gently and plug it in. Then just stick the antenna up there. There's quite a bit of room.
I found the instructions I saved. See attached.
