1 - 20 of 24 Posts
Hey guys, I just picked up a new style (08-09) rear differential cover for my 07. First thing I noticed is that the new Ribbed aluminum cover is at least 1/4 inch thicker than the stock tin cover. Will there be enough thread on my stock cover bolts or do I need to source new bolts.
Also, how much gear oil will it take, and is there a special oil everyone likes to use ?
I am pretty sure everyone is getting longer bolts... not sure on the grease (oil)
7 pints for a SRW including additive for the LS if you have it. Just get a good synthetic and fill till it comes out the fill port. I find it easier to fill from the VSS port but you still need to open the fill port to get to the right level.
Yes you do need longer bolts.
Climb to Glory!
The new bolts you need are 1-1/4" x 5/16-18. You should easily be able to find some grade 8 hex bolts or socket caps in that size.
Correct.
I was able to find a stainless allen headed cap screw and stainless washers at the local real hardware store. They really look great on the new cover.
I used 3 quarts of Mobil 1 and one tube of Trans X friction modifier and it filled it to the fill port.
Are the newer covers better? If they are where would be a good place to find one?
Thanks,
Bri
The newer covers are better in that they don't rust. Just look around for a price, you should be able to pick one up for $50-60. Do get stainless bolts to avoid electrolysis making a mess of things.
Climb to Glory!
This. The new ones are made out of aluminum, as opposed to tin, and they also have ribs/fins to help with cooling. They do not add any extra capacity just cooling ability. I got mine from Tousley for around $55 shipped. Picked up the socket caps and high collar lock washers from Fastenal.
Also grabbed a few Nord-Lock washers to check them out. Anybody ever used these before?
Here's a crappy cell phone picture for those who don't know what the new Ford covers look like.
Speaking from experience in towing heavy with this truck, the cover makes a signifigant difference in temperature.
Ive been itching to do this. Its a good upgrade and well worth the time and money for it.
I know this thread is old but I was searching for info and want to know can I use Ford's xl-3 friction modifier with Redline's 75w140 gear oil?
Also just to confirm I need 3 quarts of the gear oil and a 4oz bottle of friction modifier to top it off?
THANKS.
...and a gasket if you're replacing/removing the cover.
I believe you use a rtv silicone to seal the cover. I haven't heard of a gasket being used.
I am glad this thread resurfaced. I didn't know about this quick and easy upgrade!
How much of a difference in temperature before and after installing the aluminum cover?
What about the front diff. ? Are the 08 ones alum. Up front too?
Anyone have a part number handy?
Parts at Tousley ford has always been good to me in knowing what im talking about if I dont have a part#. Call them up you may not need a part number.
Sent from my DROIDX using AutoGuide.Com Free App
Good idea, thanks!
1 - 20 of 24 Posts
