1 - 5 of 5 Posts
· lifetime member
truck still in tranny shop. shifts 1,2,3 fine then starts to go in to 4th gear and light on overdrive blinks. everything in trans has been replaced. shop owner tells me when he tries to communicate with pcm it says error and that my pcm is bad. my sct does not show any codes. does the sct need to be installed . my custom tunes are the only ones that my truck will read because my strategy is still jan of 03. sct was in stock setting when it went to the shop.
· lifetime member
Discussion Starter · #2 ·
help
:bump::bump::bump::bump:anyone?:bump::bump::bump:
· lifetime member
:bump::bump::bump::bump::bump:
· Registered
when you go to turn it on, does your wait to start light come on?
· lifetime member
update
went to my buddy at ford dealer. said harness that plugs in to tranny was messed up and he repaired it at NO CHARGE. SWEEEEEEEEEEEET! said all of the in and out from the tranny shop messed up the harness because they were not careful . truck computer is fine. tranny shop must have out of date scanner.. BACK TO PLAYING WITH THE SCT!!!!!!!!!!!!:icon_ford::woot::woot:
1 - 5 of 5 Posts
