First time caller long time listener. I have an 2006 with around 85,000 on it. Just had the oil cooler replaced and a bulletproof egr cooler put in. ALong with ARP stud and a couple other odds and end. I want to keep this truck for A LONG time.
I don't know what my delta was before the swap(swapped it while doing some other warranty work) but now have an edge cts and notice the delta is 6-7 degrees around town and 10-13 degrees on the freeway at 65mph. I also had the coolant flushed and have ELC, Thoughts. I was hoping for a lower delta. The oil temp (196ish) is higher than the coolant temp (185ish)
No I didn't have the thermostat changed while doing the oil cooler and flush.
Great site, lots of good info.
Thanks,
BOb
Thanks,
BOb
