1 - 5 of 5 Posts
· Registered
im about to get the
GQSSB turbo kit
Swamps 250cc / 100% injectors
and ARP head studs and 810 valve springs i think thats right?
whats the easiest way to install?
i was thinking lift the body...
and do you think i should get bigger injectors?
and for all this money is this the best way to go?
thanks
Andrew
· Banned
i'd shop around, i know cass's injectors are cheaper than swamps right now, but if you are dead set on gettin swamps injectors then i would prolly get one of their turbo's and i would also get a 200 over nozzle on those inj. you can install studs and springs with the engine in. might look into an srp1, fuel system, and i hope you have a tranny to handle it
· Registered
alright, so get them from cass and get 200% nozzles
will that be over kill? i was looking for some mpg increases
i have a early 99 and gets 10mpg
and about that trans it has a sift kit, but i think i will get a built one when it happens lol, maybe my parents will pitch in when it dont move lol
· Banned
Yeah I'd say that's a little overkill for mpgs. That combo is like a 550-600 horse truck. If you want mpgs I'd do like a set of ac's 160cc aka stage 1 with an s366 on irates mount or a d66, srp1, regulated return, ect. Brought together with beans tunes. Save you some money.
· Registered
if you want to make power get 238-or 250 hybribs-if you want econ whitch is a part of being a diesel guy then check for boost leaks[diesel site leak detector] then a cold air kit,exhaust,and tuner will give you much more mpg for the money
1 - 5 of 5 Posts
