Well my mechanic says i have no compression in the #7 injector! Burnt a hole in the piston, truck smokes alot of blueish-white smoke at idle and acceleration! Mechanic says it is most likely from overfueling(from my superchips flashpaq,set on economy mode.) I also just straight piped my 4 inch exhaust about 3 weeks ago!
So my questions are this:
1: my truck blows alot of blueish-white smoke like i mentioned and vibrates really bad at idle and acceleration, it has a loss of power up until 2000 rpms and then it drives like it should and the smoke clears up! Does this sound like the symptoms of a blown motor( oh and lots of blow-by through the oil fill cap,like a freight train.)
2: what was more likely too cause this problem, the superchips(which i have had for about 6 months,set on economy mode), or the straight pipe that i had put on about 3 weeks ago?:confused:
3: The mechanic just gave me a quote for labor and parts at $5700 dollors, includes a re-honed out block, new pistons,rings,etc. Does this price sound about right for basically a new engine?
why do you need a new engine ? just pistons and rings . biggest part is labor . and I ran with a edge on setting 5 for two years except when i towed . so no it dont seem like it was the tuner.
Doesn't sound like the tuner or the exhaust. What engine? The excessive blow by and the bluish smoke do sound like a cracked piston, but if you keep driving it, it will cause cyl. wall damage.
The engine is the 7.3 liter!
Good question(top dollar)i need to ask him about why he needs to put all new parts in!
