NEW XDP Xclusive!
Baja Customs LLC has just released the New Trac-inator for 05-11 SuperDuty (4wd)
The "Trac-Inator" is a direct bolt on trac bar designed to eliminate the effects of deflection and increase steering response and control.
The design incorporates a 1" uniball and custom cup assembly that is pressed into the original stock axle location. Our uniball setup allows the use of a double shear bar mount without having to move the pivot from its stock location. At the frame mount we use a 1" rod end, instead of rubber or polyurethane bushing. The bar itself is 1-5/8" OD x 3/8" thick DOM tube and the plating at the axle mount equates to a 1/2" thickness per each bolt tab.
See website for full page, pictures and install sheet.
Baja Customs Trac-Inator Trac Bar 5033
