1 - 20 of 90 Posts
Nice article... although Im concerned about a few things...
BAD
(1) Looks like the block is a compacted powder block.. NOT a cast block..
(2) No manual transmission option, only can get it in the 6R140
GOOD
(1) It appears with the re-designed top end that most everything from injectors, fuel rails, rocker arms, pushrods, etc etc can all be done more easily now w/o having to do cab-off
Full article here:
First Look: Ford's All-New 6.7-Liter V-8 Power Stroke Diesel Engine - PickupTrucks.com News
HOLY EASY INJECTOR SWAP BATMAN!
The good:
1) Bosch Common Rail
2) Re-designed EGR Cooler & Valve System
3) 6 head bolts per cylinder versus 4 on the 6.0L/6.4L
4) Ease of repair without cab-off
5) Reverse Flow Cylinder Heads for super fast turbo spooling
6) Re-designed rocker arms which we all know has been an issue on both the 6.0L & 6.4L.
The bad:
1) As gahanna said the compacted powder block
2) Plastic Oil Pan
3) Connecting Rods are a bit light appearing
4) 2010 Emissions choking down its full potential
I'm assuming ya'll got the new issue of DP mag in the last day or 2? Great full write up in it about the 6.7. It appears Ford invited DP in to do a write up on it...
will have to check out the DP issue. with the new turbo design, i dont think upgrading turbo's is going to be very simple.... :( but hopefully it will be able to flow well enough to not need replaced when turned up :)
A plastic oil pan? wtf. How do they build a 50k truck and put a confounded plastic oil pan under it.
I also didn't like the mock up of the whole truck. The front end, rear fenders, nothing
I agree on the oil pan:tard:
I wonder if weight will be lower on the new truck:dunno:
i'm curious as to why you guys dont like the CGI blocks? they're stronger than cast iron. CGI blocks have been known to be something like 20% stronger(dont quote me on exact #'s, i could be wrong). Rally cross blocks have been CGI for a while now. so it makes sense that a super duty truck would have a CGI block since its primary purpose is to take abuse and tow almost anything you want to pull.
My only negative on the motor is the rods look kinda puny. But i dont know what they're made of either or how strong they are either....
It's very tempting. I was going to wait for job 2, but I might have to jump on this if Matts sees potential.
The compacted graphite iron is a godsend, not a weakness.
As for the plastic oil pan- well, I can think of some quotes that were made about Glock (and other polymer) handguns 20-30-40 years ago.
The manual trans has been destined to go the way of the dinosaur for a long time- the automatic technology just left it in the dust.
No more Navistar. The 6.7-liter Power Stroke V-8 is Ford's first diesel motor for its F-Series pickups to be developed entirely in-house after three decades partnering with the contract engine manufacturer. It will be built at Ford's plant in Mexico
Don't like that part either :doh:
I don't know it has always been a good time shifting your own gears... but yes I do understand the the autos are proving them self more and more....
CGI blocks are a huge leap forward for the diesel performance industry. Less wieght with more strength. How can Audi and Puegot be wrong....
I am much more concerned about the kink in the connecting rods.
i thought only the bottom half was polymer, and it was to quiet things down.
They had me sold until you said no manual tranny... Some things just feel right to me.
Matt, have you driven one of these test trucks yet?
He has, and has posted about it in a thread in the 6.4 General Discussion forum. It's a pretty good read. If I wasn't posting with my iPhone, I would put the link to that thread up.
It looks impressive but I don't think I'd plunk down 50K+ for the privilege of being the guinea pig for one of these. Maybe after they prove themselves for a couple of years.
1 - 20 of 90 Posts
