1 - 9 of 9 Posts
Well I am picking up my 6.4 this weekend. 2008 CCSB FX4. Really excited and pumped. I have decided to go with DPF/Cat delete. EGR delete. H&S either black or mini Maxx. AFE intake. and a 6" lift.
Questons
which H&S?
Stacks or no stacks. either dual black miters, or dual out the rear
What lift...Carli, BDS, or Icon. Really leaning towards BDS.
Questions is more on the lift, if anyone has experience with any of them, good or bad. And thoughts on H&S, who likes what from exp. Thanks guys. Pics soon to come. :ford:
Discussion Starter · #2 ·
No suggestions?
Don't you worry about it
2017 F250
Please no stacks but I love dual out the back corners, mini Maxx will be great and I just saw a 6.4 with a brand new BDS 6" kit on it and it looked awesome.
Mini Maxx...is it to small or a good size? and why no stacks, just not a fan? And ya BDS looks pretty awesome
Vendor
When it comes down to ride quality I would recommend Carli but I'm a tad bias... We only do a 4.5" suspension system but it will allow you to run 37" tires and will have more travel than any 6" kit out there given we maintain the factory mounting points for the track bar adn drag link allowing the suspension to fully cycle.
What kind of driving are you doing? Are you towing? What size tires are you trying to fit? Give me some insight as to how you're using the truck and I can recommend a lift system.
I like the Carli, but def seems like a lil more that I am looking for. I want 37s. Carli looks nice, but they seem like more than I need. It will mostly be a DD, tow a bronco around occasionally and a boat from time to time.
Vendor
Well, define more than you need... It sounds like out back country system will suit you perfectly.. Half of what we do is replace lifts that have nearly destroyed peoples trucks. The days of lifting your truck being associated witha harsh ride are over in the performance suspension market. Let me know if you change your mind as you know where to find me! Either way, good luck!
Discussion Starter · #8 ·
I like that the bds link has replacent arms control arms. The Carli kits just have drop down brackets. I would like the coilover system if I was going to do Carli, but dont plan on offroading to that level.
Vendor
It's not about offroading... The larger the shock diameter the better the truck will ride all around. The Kings 2.5 Pintop kit rides very plush and is our best on road kit with great off-road capability as well.
We work off geometry and shock tuning. Our coils have a progressive rate and the shocks are tuned to match the coils/add-a-packs/full springs. We drop the radius arm because we love the way they ride. I have put dirt, highway and street miles on my pintop 2.5 and can tell you the radius arms give the truck a sports car like feeling on the road, plush on the highway, and kills it in the dirt.
I found that it's easy for a four-link to overwhelm the factory sway bar and cause excessive body roll. Not saying we're doing it the only way, just our way. We keep body roll to a minimum, make the ride plush on the street and still have enough valving to play in the dirt. And to answer your question on the shocks, yes, it's $200 additional per shock and takes 6 weeks to get the kings PC custom colors.
1 - 9 of 9 Posts
