1 - 16 of 16 Posts
instruction on how to install ISSPRO gauges. I have sites that give an overveiw, but not detail. Please post or send me a PM if you would copy and fax them.
duct tape & zip ties
Which gauges are you trying to install.
all how them. Which wire goes to the boost? other than the hose. What about all the other gauges where does the wire go to light them up and stuff
and i'm doing the CCV mod. what do i need? i'll just run the hose down then along the frame untill i get behide the cab. what size hose and how do i mount it
Desert Shield/Storm Vet
pm sent:thumb:
Discussion Starter · #10 ·
thanks again vitalidle, now if someone could tell me about the CCV mod i would be all set. I was told i don't have to make an oil trap, just mount the hose and run it behide the cab, along the frame. how does this mount?
Some people do just that, how ever they put a breather filter on the end of the hose.
Let's go B's!!!!
You have to turn that 'doghouse' around. :thumb:
Let's go B's!!!!
Are you reading guzzles link?
He explains everything there.
Good Luck
1 - 16 of 16 Posts
