Vacuum Pump! (because there's no Throttle Plate to "pull against", most diesels don't make good vacuum). They almost always run when you first roll-on the key, if it never shuts off then you probably have a leak (usually in the hub lines if you have EOSF 4WD)
Plays No Part in Starting though...
