03/04 ford van and something got sucked up the oil pick up and tore the heck out of the low pressure oil pump gears and front housing were the georotor gears are... were is the best place to buy that front cover???...
There are a couple of this sites sponsers, tousely ford for one that has good prices and service.
By the way you may want to fix that pick up screen and find out what that something was that took out the pump. If it's not all out you can be doing this all over again. A lot of work I know but is it worth the chance of even greater damage.
I wouldn't put a front cover in it just yet. Like said before you need to find the source of the damage. Suspect possible roller lifter failure in this case.
