1 - 5 of 5 Posts
how do i get the dash bezel off without breaking the dimmer switch ? :doh:
u mean the light switch
by dimmer do you mean the "headlight" switch, it just pulls off and then you carefully pry the dash off after taking out i think like 2-3 screws.
mine just pulled off with some effort after you pull the switch all the way out.
i think this is what you are talking about, had my dash off about 10 times so i don't even think about it. side note, when you pull your little trim pieces off make sure your floor is clean and you do it slowly, the little metal clips are prone to fall off and drop to the floor as you pry.
Electrical Ogre
Pull on the headlight switch, rotate it until you see a slot in the plastic. Press a small screwdriver into the slot and slide it toward you. It will release the metal clip that holds the knob to the shaft.
If you dont have a small flat screw driver use a paper clip!
thanks guys but i got it :thumb:
1 - 5 of 5 Posts
