1 - 7 of 7 Posts
First off in my fuel bowl while changing the filter I noticed little droplets of oil what exactly does this mean? Secondly I have a 99.5 with a six speed manual and I was wondering what kind of power will be maid with and afe stage II intake, exhaust, and of course gauges with a dp tuner the truck is all stock right now and I am looking into getting these things thank you in advance for all of your replies.
dont know about the oil drops so this will act as a bump
i think you'd be right in the 300 hp range maybe slightly higher.
if im wrong im sure i'll be corrected this truck will accelerate like an animal
i switch mine back to stock every once in a while and it doesnt stay there long.
added bonus it will give you better fuel milage if you keep your foot out of it..
good luck
Are you sure it is oil? Could be water droplets in the fuel. Since water and fuel or oil don't mix. And +1 for the HP range.:thumb:
Could be injector O rings, but just keep an eye on it for now...
You should be about 300-320 with a 6 speed, the auto's loose a bit more.
What if it is the injector o rings what should i look for and what kind of effect will it have on the engine
where is the oil, are you sure it is oil .
fuel bowl orings die pretty common..
also hpop orings can go.( which is right under the fb)
orings and injectors are joes dept.. I haven't touched mine yet...
as far as how much hp
...not sure exactly what the real range is ,
but will sure make you happy.
i dont see how oil could enter your feul bowl.....make shur its oil if so.....an injector or 2 prolly bad......got a plunger sticking open........
1 - 7 of 7 Posts
