1 - 1 of 1 Posts
So I have a 6.7 Powerstroke 2014 f350 With 210k miles Single rear wheel so I changed the glow plugs And I wanted to see if it had a power difference which it did big time and I did 2 small burns the next day I started to hear like a weird sounds like if something was loose. And you can start hearing the sound when I would press on the pedal and my father in law was looking around the motor while I pressed the pedal and we noticed at the hot side pipe would move up when I would press the pedal at 4K Rpms and it’s pretty loose you can moving it. Are you suppose to have a movement with tha pipe and it looks blown where it connects to the turbo it still holding on but looks worn would tha be my problem causing tha sound
1 - 1 of 1 Posts
