1 - 2 of 2 Posts
Question is: do I need/have to use the 4x4 module to make the transfer case shift positions?
So I have all the hard parts already for this conversion.
_*2007 F350 Dana 60 front end and suspension
*Electric shift transfer case
*4x4 4r100 wiring loom
*Dash switch with some wire but no plug
*4r100 4x4 transmission core
I do not care about dash lights saying 2wd or 4wd.
I will not be using the auto engage hubs - If I want 4x4 I can get out and turn the hubs.
So I do not need the vacuum and all the other involved parts to make them work.
I do not want a manual transmission
I own everything already and do not want to change floor to put in a manual shift transfer case, as I have custom center console for camping/driving.
Thank you for your help - Daryl
Discussion Starter #2
I spent about 4 hrs searching the net yesterday and all the info seemed to not cover the Electric transfer case wiring.
No wiring diagrams I can understand either.
Did find a video of a guy that just tricks the electric shift motor into shifting with a dual throw toggle switch.
1 - 2 of 2 Posts
