A miss started in my '96 7.3 PSD recently and got worse after heading back home. Thought it could be fuel filter so replaced with no help, old filter was clean. Check engine light is on. Engine hard to start, missing and does not want to rev up. Left exhaust maniflod cold, so thought it could be UVCH. Removed valve cover and found burnt connection, so replaced gasket and both injector harnesses. Restart and still have same symptoms, miss and cold exhaust manifold.
Cam position sensor, glow plugs and relay have all been replaced in last 20,000 miles. Engine has been running good until now, only has 120,000 miles. Truck is F-250, auto trans, 4x4.
What should I check next? Any help is much appreciated.
