1 - 2 of 2 Posts
I was just outside adjusting the alarm parameters for my live wire tuner when it froze up I tried holding ESC to see if it would turn off.....after several mins and nothing I unplugged the Tuner to turn it off. When I attempted to turn it back on the screen says.....
Invalid Block Read ID
-442503144
2048
-1770012576
I tried to hold the ESC Button to turn it on and get nothing. I unplugged it and took it inside and hooked to usb on computer and get the same thing!
Does anyone have any Idea what is going on with my tuner?
Is it safe to drive the truck without the tuner hooked up? I have always had the tuner plugged in since the dpf delete.
Any ideas to fix this would be great as I have to drive the truck in the morning and SCT is closed until monday.
Edit/Delete Message
Discussion Starter #2
adition
I am assuming that I am ok to drive the truck since my program has been flashed to the ecu. I just want to double check before I leave work to go home in the am.
1 - 2 of 2 Posts
