1 - 2 of 2 Posts
I have a new problem that has popped up. I changed the fuel filter on my F-350 7.3 and spilled some diesel on the manifold. Around the glowplug on the left side of the engine (facing it) It appreared that there was air? coming out of the engine and or it was boiling. There were bubbles in the fuel it looked like someone blowing through a straw in liquid. Im really worried right now. what can this mean? Any ideas.....................
Badasp118:dunno:
bubbles around glow plug would tell me compression is bleeding through the threads id remove the glow plug clean it up and install it and make sure its tight when you put it back in also good time to check and see if its good
1 - 2 of 2 Posts
