1 - 8 of 8 Posts
got a 2000 powerstroke i have a small chip and a turbo upgrade. the past few weeks ive been loosing boost and my egt have been getting to high. did a leek check and found nothing wrong with the intake and the turbos fine. really need some help.
you are sure your turbo is fine?
turbo is a week old and i put 15 psi on the intercooler, pipes, and intake and couldnt find anything
No but if the cat is clogged up, assuming you have one, this would make you lose boost also.
International Threat
2000 = no cat
sounds like an exhaust leak.
Check your uppipes since you just did the turbo. Also, did you put the big O ring on the intake side of the charger?
Discussion Starter · #8 ·
its streight piped and i cant find any carbon at any of the joints between the manifold and the turbo. but what about the ebp sensor the line was stopped up could that do it.
1 - 8 of 8 Posts
