I am replacing ball joints on my 07 F250 4x4. I have everything back together, but after installing the hub and torquing down the hub nuts on the back, there isn't enough axle sticking out to put the inner snap ring back on. I disassembled and removed the axle again, used the inner seal tool to verify it was seated on the axle, and then reassembled.
Still no luck.
I inserted the locking hub and it seated just fine.
What did I do wrong? I don't want to leave that inner snap ring off.
thank you in advance.
Jeremy
Still no luck.
Jeremy
