93 f250 7.3 idi na .. I am leaking fuel from the bottom of my injection pump. Its running through the valley and down the back of my motor to the ground. Ive traced the leak to what i assume is the weep hole however am not certain. It starts runs drives fine cold start idles perfect except the leak ive inspected all my return lines the access door the gasket seal on front of gear housing and all seem to be fine . the leak is coming from the larger of the 2 holes on the bottom of the ip. I am about to purchase a new ip but if its something simple.or something i can fix id much rather... I have the orig ifs db2 5013 ip truck just hit 179k ... Please any advice or suggestions would be much appreciated
