1 - 10 of 10 Posts
I am trying to piece together a build that will get me into the some nice power for a 6.0
I am gonna be buying a 2004-2006 6.0 and so far this is my idea of what I am going to need.
Headstuds guages 4 inch turboback and a IDP XCAL 2 or 3 with some nice tunes :icon_ford:
what can I be expecting HP wise with this setup?
what other upgrade should I consider down the road?
How much power can a 5R110 hold stock before I need a aftermarket setup?
Turbo? Intercooler? CFM+ intake manifold? HPOP?
need advice.
need advice,
It all depends how much you fast you want to go/spend.
12 second daily driver. extended cab shortbox 4x4.
thats alot of dough
sounds good dont forget the guages:nod:
DKR is running 12.95 on studs, IDP tuned x3, largemouth intake manifold and 150 Dry shot of nitrous.
Which should cost under 2k (assuming you do the studs yourself).
<--Pro Cooler Racer
^^^^ Yup to HaroHunter:D
Mods are in my sig...if you can do the studs under warranty (recommend) or by yourself...you are looking at approx. $3000-4000 depending on which programmer and what makes of mods you get.:thumb:
Echo on here is 13 flat (Reg cab Long Bed 4x4) on tunes and exhaust only.:thumb: But he weighs a lot less then I do.:nod:
Mine is a daily driver/work truck, I have a "stepped down" tune I use daily.:D
1 - 10 of 10 Posts
