1st... b4 u do anything... u NEED gauges, and prolly go ahead and install a large transmission cooler.
2nd... check ure fuel pressure at WOT, it will prolly be below specs (anything below 50psi) which means u should bo e-fuel. The reason i say that is once u open up the flow ure fuel pump wont be able to keep up. Every time ure fuel pressure drops when u get on the skinny peddle u will be slowly destroying your injectors that u just spent so much on and save up for...
3rd...go ahead and install injectors and check out under valve cove harness and glow plugs.. if u havent done the intercooler yet u will have to watch egts like a hawk and if u tow at all then i would recomend doing it first.
4th..... get ure chip and have them detune it untill u can afford a turbo so u dont blow it apart.
5th... upgrade ure HPOP... reason i say not to upgrade earlier is low HPOP pressure will not cause any damage, just low performance and bad fuel economy. Once upgraded u can reburn chip or leave it like it is untill u swap the turbo.
6th... upgrade turbo... d66 or if u wana go all out, t4 mount kit and an s366.
Ure trans will blow in there somewhere which at that time go ahead and either swap in a zf5 or build the trans.
