1 - 20 of 285 Posts
***2 August 08 - Note - post 5 updated on the install. Thanks!!!***
As some of you know, I recently started my Vegistroke install and figured I'd start a thread to capture my progress as I go. Also, hopefully this will serve as a supplemental guide to the instructions that DFA provides with the kit.
As a note, this is a work in progress, so bear with me as I update it from time to time. It'll probably take a while for me to complete the install (work full time, etc), but I hope to wrap it up soon.
Also, as I mentioned in another one of my threads, right now I'm missing some fittings for the kit. Therefore, after talking to Clay on the phone yesterday, I took his advice and decided to focus on installing the parts I could until I get the remainder of the fittings in from DFA. So, what you'll see doesn't necessarily follow the order of the instructions, but should still help when it comes time for others to install theirs.
Here's a couple of my other threads with possibly helpful info:
http://www.powerstroke.org/forum/bio-diesel-alternative-fuels-supplements/53624-vegistroke-owners-60-gal-toolbox-tank-help-me-out.html
http://www.powerstroke.org/forum/bio-diesel-alternative-fuels-supplements/53694-vegistroke-installers-i-got-quick-question.html
First off, here's a couple pics of the hardware to expect as well as the wiring harnesses you'll receive from DFA.
Main circuit board harness:
Frame harness:
Fuel level guage harness:
Main (underhood) power harness:
Fuel level sender (from tank) harness:
Tank connections:
Left to right: fuel level sender wiring, coolant in/out, fuel return, fuel out, coolant in/out, vent, and of course filler neck
Hardware (note that this is not all of it - missing a few fittings):
Not pictured are the plastic "T's" for tapping into the coolant lines for the tank.
Also, after talking with Clay yesterday about the need to possibly drain the tank, I spent some time mocking up a possible drain and valve setup for the drain plug on the tank. Here's a possible setup that I considered, but I've realized it'll need to be changed later to actually work. I'll update that once I get it complete.
So, on with the install...
First for me was the tank:
Driver's side of the tank showing tank hardware and the hole I cut in the front corner of the bed to run the lines through.
Better shot of the hole:
To be continued...
Discussion Starter · #2 · (Edited)
Here's a shot of the passenger side.
Shot showing the clearance needed between the tank and the bed. Yes the front of my bed is bent a bit. Previous owner got a bit excited loading his motorcycle...haha.
Another shot of the hole with a piece of 1/4" tubing installed that has been split down one side to protect the coolant and fuel hoses from the sharp edges.
Mounting plate fastened to the module. Note that I used blue Loctite on these nuts since the bolts in the rubber isolaters weren't quite long enough to fully pass through the nylon locking portion of the nuts. I'll be checking these periodically to ensure they don't come loose.
Shot of the trans crossmember bolts that are used for mounting the module. The bolts are captured from the top, so you only have to remove the nuts.
Module installed. Blue Loctite was used here also.
A close up shot of the mounting plate on the module. On my 05, I had an issue getting the mounting holes to line up with the crossmember bolts. Then I realized that there is a slot in the suspension bracket that the module bracket must slide up into in order for it to line up. Just wanted others to see a better view of what I was talking about.
Another shot of the module looking toward the rear of the vehicle.
View from below looking up at the hole I cut in the bed. The following shots show how I routed my first coolant line and how I'll run my other fuel and coolant lines as well. As a note, all the zip ties you see in the following pictures are only temporary to hold the line in place. Once I get the remainder of the lines ran and wrapped with insulation tape, I'll replace them with the new ones provided by DFA. Also, here again, I used a piece of 1/4" tubing, split down one side, to prevent the line from rubbing against the sharp edge of the bed.
Running the line down the driver's side of the frame.
This is where I decided to bring the hose over to the passenger side of the truck. Right in front of the fuel tank, above the frame to prevent the hose coming in contact with the drive shaft or the exhaust. This is looking toward the rear of the vehicle.
Shot of where the line comes down and runs toward the module.
Connected to the module.
And finally, connected at the other end to the tank.
That's it for now. Like I said, not much, but it's a start. I hope to spend some time on it tomorrow once I celebrate Father's Day with my Dad a bit. My next step will be running some of the electrical harnesses and possibly the fuel return line from the module back to the tank. I should have enough fittings to get that done until DFA sends me the ones I'm missing. I also plan on setting something up to mount the switches lower on the dash near the trans tunnel. I don't particularly want to cut into the dash, so I should be able to mount them lower but still monitor them while driving.
Until I get all the other lines hooked up, I made sure to either cover them with tape or put the caps on them that DFA provides. I also put plastic bags with zip ties around the unhooked connectors to prevent unnecessary contamination. Just a tip I thought I'd share for others that may be installing their system a piece at a time like myself.
After that, I'll basically lack replacing the front banjo bolts, tapping into the back of the heads, running the fuel lines and tapping into the coolant lines. I'll be sure to update as I go.
Thanks!
****Update June 15, 08****
Just a quick update - Ran the return line and hooked up the vent tube. Got a late start this evening, so time was limited. No pics for now, but once I get some of the other lines ran, I'll snap a couple pics. Hope to install some of the electronics either tomorrow evening or Tuesday evening.
****Update June 19, 08****
Was looking over some of the wiring the other evening and snapped a quick pic of the grommet behind the pedal for running the main harness into the cab. Figured I'd post the pic.
Also, for those who have been following the thread and have noticed all the discussion of the Bio's leaking heat exchanger in the tank, I decided to pressure check mine tonight to see if I had any leaks.
After talking to Clay today, I decided to follow his advice and fill the exchanger only with water. I decided against air due to the chance of blowing a weld apart from over pressuring. I'll give it overnight and see if anything has changed. Here's a pic of what I came up with to monitor the amount of the water inside the exchanger.
Basically I just picked up a PVC 90 degree elbow that goes from 1/2" NPT (male) thread to a 5/8" barb and a small roll of 5/8" ID clear tubing. Pulled the hose I already had hooked up on the supply side, attached my elbow and tubing to the return side, filled it till water ran out the supply side (to get the air out), capped it off and then finished filling the tube up till I could see it. Marked it with a marker and then put a small piece of tape over it to curb any slight amount of evaporation I might see overnight. Should work pretty good I think.
Hopefully will have more to add tomorrow. And if I'm lucky, this darn tank won't be leaking!!! Wish me luck.
Thanks!
***21 June 08***
Well, I got another day to work on the kit yesterday so I figured I'd pick up where I left off. First off, regarding the test of the heat exchanger, (I think I posted about it later in the thread too) I feel pretty confident that it's good to go. Yesterday morning when I checked it, it had dropped about 1/2" below the mark I made the night before. However, as the day went by, and temps rose, I quickly realized that the level was rising. By the time mid-day rolled around, the level had actually surpassed the original mark. So, I concluded that the expansion and contraction of the water was the main cause of the change in water level.
My final test will be running the truck for a while, parking on a hill with the tank drain downhill and then pulling the drain to see if any leaked out. At this point, I feel pretty confident that the tank is fine.
So on with the install...
Here's a quick shot of the grommet from the underside of the truck. This should give you an idea of what you're working with when it comes time to run the frame harness into the cab. It can be an aggravating experience, so patience is the key. I passed the 6 pin connector through first and then fed the smaller connectors through. You'll have to bend the wires over on the 6 pin connector, so be careful not to damage them when pushing them through the hole. Luckily the metal in that area doesn't have sharp edges.
Shot of the main harness passed through the hole...
Here is how I mounted the main electrical board temporarily. I tried mulitple positions, but to be honest, since there is so much stuff under the dash, there is really no good way to mount the board. Looks a bit ghetto at the moment, but I might try to straighten it up a bit later.
For the frame harness, I brought it down the driver's side of the frame first. I did this since there are two wires on the harness that must connect to the 12V power source on the stock fuel pump. This will be a green and black wire. Here is a good shot of the fuel pump/main filter housing where you will tap into the wiring. This was taken from the 6.0L Bible that can be found here:
6.0L Bible Table of Contents
There is a ton of other great info to be found here - a lot of which I found helpful when doing the install.
Here's the actual page that gives the layout of the housing. This would be if you were laying under the truck from the drivers side looking up at the housing.
Shot of the frame harness (I haven't spliced the wiring yet).
Shot of how I ran the harness over the front driveshaft.
Shot of how the harness was ran under the trans crossmember.
Another shot of how the harness was brought around to the module.
Next I ran the underhood power harness. A quick shot of how the harness was ran up towards the battery.
A quick shot of all the connections on the module. Most, if not all, connections on the DFA harness are numbered for ease of installation. I think there might be one or two that aren't for some reason, but you can figure it out by shape and the process of elimination.
Ran the fuel level sender harness back to the tank.
For my truck, this harness was a bit long, so I just looped it up and zip tied it out of the way.
And finally, hooked up the sender at the tank.
Next up for me was replacing the front banjo bolts. I'll warn you up front, this can be very frustrating at times. At least it was for me.
Here's a shot of the drivers side location for the front bolt. This would be looking from the front of the truck, just to the left of the airbox. To get to this little jewel, I had to remove the air filter, a small coolant return line to the coolant expansion tank, the intake tube running from the intercooler to the intake and I believe the intake "duct" if you will that runs through the front of the grill area.
And by the way, if I ever run into the Ford engineer that designed that airbox assembly, I'm gonna have to restrain myself. What a stupid design....
Anyways.
Another...
Here is a tip. As Clay predicted, once you remove that hose, coolant will proceed to go everywhere. Out the end of the hose. Up out of the water pump at an amazing rate. All over the ground and down the driveway. You name it, it'll be there. Another tip from Clay - once you pull that hose, have a rag handy to shove down in there ASAP. It'll stop the flow long enough to get done what you need to get done.
Once you get the coolant flood under control, you can proceed to removing the bolt. I simple combination wrench (19mm I believe) will take care of it. The re-installation is the tricky part. If you heed any of my advice during this install, please listen to this.
Loosen the other end of the line on the secondary fuel filter housing before trying to put in the new bolt from DFA.
Do I need to say it again? Haha.
Trust me, save yourself the two hours of frustration that I experienced and just loosen the other end of the line. Once you do, it shouldn't take you long to get it in there. By this point, your hands will be a diesel/antifreeze soaked mess, so anything to make the job easier will be a blessing.
Installation is the reverse of removal. Coat up the bolt with Loctite (even though it'll likely dry before you get the bolt in there - mine did) and snug it up good.
Also, now is a good time to hook up your coolant return line if you want to, while the coolant is drained out of the hose. If you look along the back of the engine bay, at the top of the firewall, you will see a line coming out of the heater core and running over to underneath the coolant expansion tank. This line is the same one you loosened on the water pump and is where you want your coolant from the tank returning to the motor. I believe Clay hooked his up on the other end (where it comes out of the firewall), but my location looked easier to me at the time. Appeared is the key word here.
It's not easy to get too, but seems to work fine. I've ran the truck (on diesel) and I'm getting plenty of warm coolant to and from the tank. Here's the shot.
Before cutting into the lines, to minimize an further coolant loss, I heeded Clay's advice and used a pair of vicegrips to clamp the hoses off. It saves some mess, trust me.
On to the passenger side...thought I'd never get here.
This one is much easier to get to. I didn't have to disassemble anything else on the truck to get the bolt out. I will say to be careful when moving the line around trying to get the new bolt in. While it's not bolted down, there are guides on the head that hold the line in place. Pull it too far and it can be hard to get back in. I also removed the other end of the line on this one, but I'm not sure how much help it was. I did get it back together though, so apparently it helped...
For your coolant supply to the module and the tank, you'll want to splice into a hot water supply from the engine. Right above the passenger side valve cover, there is a rubber hose that comes up from a metal hose off the water pump. It runs toward the firewall into the heater core. You'll notice that there should be a small, vacuum operated valve in this line.
Your splice will need to be on the engine side of this valve - or toward the front of the truck. This is key.
Here's a shot of how I spliced mine in. When I cut the line, I clamped it with vicegrips, and put a rag over the electronics below. However, by this point, if your's is like mine, there won't be much coolant in the line.
That's all I got for now. I did work on the truck today, focusing on the rear lines. I didn't take any pictures today as I was working against the clock (had somewhere to be this evening), but it's nothing I can't shoot tomorrow and post up tomorrow evening.
I'll warn you that the rear bolts are frustrating, but I'll save the details till I get the pics up. I'll also provide some tips on what to use in order to get the plugs out and the new bolts in.
Right now, the truck is all together and running. All I lack is splicing into the stock fuel pump 12V supply, hooking up the main power harness under the hood, hooking up four wires under the dash and installing the fuel level gauge for the tank. Shouldn't take too long.
Before cranking the truck, I made sure to top off the coolant. Overall, I think I put about two gallons back in - replacing what I lost and filling up all the lines and heat exchanger in the tank. This took a while, starting the truck, shutting it down. Repeat. Repeat. Finally, I let it get to full temp and then cooled one last time. It should be good to go now.
There were some tense moments on the initial starting. Truck cranked fine and there were no leaks, however the engine had somewhat of a shimmy to it. Warmed up to temp, still doing it. Step on the pedal and it's still there. Took it around the block and the truck seemed to hesitate and stumble a bit. No warning lights, no overheating, nothing. Brought it back to the house and shut it down. I had to get on the road, so the wife and I took her car so the truck could fully cool while we were gone.
Got back a bit later and I checked the coolant and fired it up again. Still doing it. Stepped on the pedal a few times and then the shimmy just up and quit. Drove it to the store and back and all appears good now. The only thing I can figure is that there was some air trapped in the lines/rails somewhere. I imagine the heating/cooling process helped eliminate it.
So, all appears good for now. Admittedly, I was scared there for a bit, that I had just made a big, big, big mistake.
More pics to come tomorrow. I've had enough for today.
Thanks!
Discussion Starter · #4 · (Edited)
Finally got a chance to snap the pics of the rear bolts. Sorry for the delay, been a busy week. Anyways...
First up, a couple more pics of the parts that DFA sends with their kit.
Fuel level gauge.
Control switches.
Gauge mouting pod for the column.
Also snapped a pic of the stock front bolts and the rear plugs once I got them out. Just figured there would be some folks that would want to see them.
First up, driver's side. This one definitely proved to be the harder of the two. Tried to get a good pic, but it's cramped up in there.
And yes, I do have the wonderful bell housing leak and my drain plug is seeping. I plan on replacing the plug when I do the next oil change. I'm sure everyone will notice it in the pics. :)
You can see the the line is almost directly behind the up pipe for the turbo. Therefore, removing the stock plug and putting in the DFA bolt can prove to be a challenge just to get your tools in there. What I ended up using for removing this was your basic 1/4" drive, 6mm hex bit in a 1/4" combination wrench. One trick I'd advise considering is taping the bit into the closed end of the wrench. This helps by being able to move the wrench around without worrying about losing the bit. You'll find that once you get the wrench and the bit in place, it'll be hard to get enough leverage on the plug to break it loose. A 1/4" wrench is typically so small, that it'll tend to bend or give quite a bit. I finally had to position the wrench just right so that I could get a larger, 17 or 19mm wrench over the other end of it to use as a cheater. Worked like a champ after that. Here's a pic of what I'm talking about.
Obviously since getting the stock one out is a problem, getting the new one is as well. What I finally had to do was cut down a 17mm wrench so that I could get it in there and tighten the bolt. Here's a pic...
Passenger side seemed to be quite a bit easier.
Used a little different setup to get this one out. Used the standard 6mm hex allen wrench, with a 6mm socket on the other end with a 1/4" extension on it so I could get some leverage. Here's what I'm talking about.
I was able to actually reach up over the passenger side up pipe and remove this one from the top. Installation wasn't near as bad either. Started it by hand and finished it off with the modified 17mm wrench I showed you earlier.
Finally, here's a couple shots of how I ran the fuel supply lines back to the module. The drivers side is ran up over the bell housing of the trans. From there, it joins up with the passenger side over near where the trans fluid level dip stick comes down. Here's a shot...
From there they pass through the frame in a hole just behind the passenger front tire. You'll see what I'm talking about once you climb under your truck.
From there, they T into the 3/8" fuel line that runs to the module.
So far I've got probably 400-600 miles on the truck and everything seems fine. Coolant level is okay, no overheating and the truck performs as it did before I ran the lines to the back of the motor. Still lack a bit of wiring and putting in the fuel level gauge, but I hope to take care of that tomorrow and have the system fully installed. After that, as soon as I get my filtration setup complete, I'll try it out on oil.
Only thing I noticed (that I plan to ask DFA about) is the yellow, plastic washer's on the JIC fittings. I noticed the two on the rear lines showed a bit of deformation from the heat of the up pipes. I doubt these will degrade performance as they have nothing to do with the line staying on the fitting, but I figured I'd check with them. I also want to make sure that the hose is made to stand up to that kind of heat for a prolonged period of time without any protection. May have to wrap them with something.
More to come...
Thanks!
Discussion Starter · #5 · (Edited)
****Update - 2 August 08 - Also posted this toward the end of the thread.****
Been a while since I got on here to update. Took Monday afternoon off to finish up the install before I head out this weekend to the beach.
Unfortunately, needless to say, little to no progress was made. :doh:
Ran into some snags when trying to wrap up the wiring. First off, I don't think I have the correct gauge pod for the fuel level gauge. Second, my "engine run" wire (behind the central junction box under the dash) is the opposite color from what DFA says it should be. I believe blue/white is what they call for on 6.0L PSDs, but mine is light green/red, which is supposed to be for the 7.3s. Also, it took me forever to find a 12v switched source. Finally found a suitable one right beneath the column, so I'm planning on using it in conjunction with a "add a circuit" and a relay. This should help minimize the hacking I have to do into the factory wiring. If I get a chance this evening, I'll post up some pics of what I found and what I plan to use.
So, I ended the day with little done other than finding some wires and running into problems. Story of my life... :tard:
Anyways, I need to call DFA on a couple of the issues above before I can finish it up, and I'll be going out of town for the weekend, so it'll be a few more days before I can wrap it up.
I apologize for the delay to all those watching the thread. Really was hoping to have it done before I left for vacation.
So...bear with me and I'll try to get it wrapped up ASAP. Now that I've found all the wiring and know what I'm gonna do, I think I'm only a couple hours away from calling it done.
I'm a big fan of taking my time and doing things right...guess that's caught up with me this time. :banghead:
Wiring never was my specialty either...:doh:
Hang in there...I'll get it wrapped up soon. Thanks for the patience!
Thanks!
***Update - 7-14-08 - Finally wrapped up the install***
So, to wrap it up, the main thing I had left was the wiring under the dash. As I mentioned in my earlier post, I ran into some problems regarding the gauge pod and the wiring under the dash. Wiring was a different color than what DFA called out and the gauge didn't fit in the pod as I expected. Here's a couple shots of what I'm referring to.
First up, shot of the wiring harness for the gauge.
Here you can see how the mounting studs on the back of the gauge interfere with the back of the pod. Also, I'm pretty sure DFA has sent me the wrong pod, so for now I don't have the gauge installed in the truck.
So, I pressed on with the wiring. Here's a shot of the wire location for the "engine run" wire the instructions call out for tapping into. This is pin #4 on connector 270C on the back of the central junction box under the driver's side dash. The lower left hand side of the connector in the picture is pin #4 (red and light green in color).
Another shot. This is under the dash looking back at the door. As a note, the light green/red color combo is the opposite of what DFA calls out for the 6.0L PSD. Per the instructions, the 02 and earlier I believe 7.3s were supposed to have this color. However, after talking with Jason at DFA, Ford apparently changed the harness colors over the years. As long as you use the wire located at pin #4 on the 270C connector you should be fine though.
Since I couldn't go ahead and tap into the engine run wire, I decided to find a 12v switched source so I'd have that out of the way once I got clarification from Jason at DFA. After much time with a meter, I did find one location right under the steering column. The red/light green wiring in the picture below is a 12v switched source.
Fast forward to this past weekend. Got the answers to my questions and was ready to wrap this up. First up, find a good grounding location.
This is right beside the hood release, just below the line of the carpet.
Just for the record, thought I'd throw in another shot of the engine run wire - noted by the tip of the screwdriver.
Spliced into the wire...
****NOTE 8-2-08 - ORIGINALLY I COULDN'T FIND THE 12V SWITCHED WIRE THAT DFA CALLS OUT IN THE INSTRUCTIONS AND DECIDED TO USE THE RELAY SETUP OUTLINED BELOW. SINCE THEN, I HAVE FOUND THE CORRECT WIRE AND HAVE ABANDONED THE RELAY SETUP. A SHOT OF THE CORRECT WIRE IS BELOW. HOWEVER, IN CASE ANYONE CANNOT FIND THE CORRECT WIRE, I'M ALMOST CERTAIN THE RELAY APPROACH WILL WORK FINE. BEFORE DISCONNECTING IT, I VERIFIED THAT IT IS A SWITCHED SOURCE - DEAD WITH THE KEY OFF, 12V WHEN THE KEY IS ON. THEREFORE, I WILL LEAVE THIS INFO IN HERE IN CASE ANYONE WANTS TO GO THIS ROUTE. HOWEVER, IT'S AT YOUR OWN RISK. THANKS!****
Now for the 12v switched source. After some thought, I decided to take a little different approach than what the instructions call out. In order to avoid over loading any of the stock wiring, I chose to use a relay to create a new 12v switched source. For this, I would need a trigger wire, ground, 12v constant source in and a 12v constant out to run to the Vegistroke harness.
For my 12v constant, I simply ran a wire from the main power supply to the central junction box.
So, for the trigger wire, I used an "add-a-circuit" to run a stock 12v switched source to the relay.
If I'm not mistaken, I placed this in slot 45 of the central junction box. I can double check and clarify if need be. For those not familiar with an add-a-circuit, it is basically a replacement for the stock fuse that has a wire already wired into the housing. It uses two fuses, one to replace the stock fuse and one for the new wire that it provides. Be sure to put two fuses in the unit - don't be like myself and forget and then wonder why you have no instrument panel power...haha. The great thing about this is that you don't hack up the stock wiring and it's totally reversible if you ever want to pull it out.
Shot of the relay. I chose to mount this on the metal bracketry of the parking brake. In the photo below it's not quite in position, but once I had everything where I wanted, the pins on the relay were facing the firewall to ensure nothing interefered with them.
Another idea I came up with was to run the 12v switched source through a distribution block before attaching it to the relay. This way I can add gauges and other items down the road that require a 12v switched source without further cutting of the stock wiring. I also mounted this on the metal bracket for the parking brake.
A final shot of everything hooked up.
As a note, you will need to modify the lid on the junction box to get it to go over the add-a-circuit.
Also, you will probably need to cut the grommet to get all the DFA harnesses to fit in the hole that passes through the floor.
So that's about it. Only other things I did that I didn't snap a picture of, is the main connection to the battery and the splicing into the stock fuel pump wiring. These are pretty straight forward, so I figured most would know how to handle it. But, if anyone needs a pic, let me know.
As a note, on the stock fuel pump, the green wiring on the DFA harness goes to the connector side of the stock fuel pump harness. The black wire will go to the truck side of the harness. DFA's instructions explain this pretty well.
That's about it really. Only thing I lack is the fuel level gauge and wrapping the lines with the insulation tape. I figure that's pretty straight forward as well, so I doubt I'll snap any pics. But, again, if anyone needs a hand, let me know.
So, for now, my truck is ready to burn vegi as soon as I get some oil filtered. I'm glad I got it wrapped up finally. Been a long project, but I'm sure it'll be worth it the first time I cruise by that fuel station!! :)
Thanks for all the support!
***EDIT - Update 8-2-08***
Finally got a chance to hunt down the 12V switched source that DFA calls out in the instructions. After talking with Jason at DFA, I decided that it would be best to use that wire if I could find it.
If you follow the harness for the OBD2 port just under the edge of the dash, you should find the dead-ended customer access wires that DFA refers to. I either missed it before, or just didn't look hard enough.
Here's a quick shot.
The wire needed for 02 and newer trucks is white and light blue. For now I'll leave the 12V relay setup info in here in case anyone wants to pursue that path at their own risk. I'll be sure to put a note about it earlier in the post however.
Did determine that I do have the wrong gauge pod - somehow I got the 6spd pod instead of the manual. Jason is shipping the new one to me, so I'll snap a couple pics of that once I get it put in. Last thing on the list will be mounting the switches. I didn't want to hack up the dash, so I opted to go a different route. I plan to pick up a project box from Radio Shack and come up with my own mount. I'll take a couple pics of that as well when I'm done.
Now if I can just get the water out of my oil during the filtering process, I'll be in business. :banghead:
Thanks!
Marv this is good information. This information is going to help me with mine. Would you mind giving me the measurement from the inside front of your bed (back of the tank) to the front of the tank? I have a 5th wheel hitch and I hope it does not get in the way. I measured it before I ordered the tank but I did not take into consideration needing that big of a gap. Thanks.
Discussion Starter · #7 ·
Triple, sure I'll get that measurement for you. Probably be later today, but I'll get it.
Thanks!
subscribing
Marv:
What a great blessing for us to have you foto the process. Thanks. Smart to place a empty place holder Message to go back and edit. This way we can copy and print your install in successive steps. You guys have it together here.
Bob Gieser
great info bud... im gonna keep an eye on this as i am really thinking about getting a kit myself. again, great work!!!!
Marv, it looks like you are planning to run hoses in seperate locations?
These hoses should all be in one bundle together... hose on hose to keep the fuel lines warm.
Discussion Starter · #12 ·
Triple, I measured from the inside front of the bed, to the front of the tank (side facing the tailgate) on both corners. It's between 21 7/8" and 22" even. I decided to measure at the corners of the tank due to the front of the bed being bent a bit as shown in the pictures above.
Hope this helps. Let me know if you need anything else.
Thanks!
Discussion Starter · #13 ·
Marv:
Bob Gieser
Bob, I'm just glad I can help. You're more than welcome for the photos and I'm sure more will come.
I know how frustrating installs like these can be and pictures always help me out tremendously.
Thanks!
Discussion Starter · #14 ·
Thanks Rob, I appreciate it. It's obviously a work in progress, so I'll stay up to date as best as I can.
Too bad those pesky day jobs get in the way with working on the truck! Haha...:rofl:
Thanks!
Discussion Starter · #15 ·
Clay, I'll be running them all together. Right now all I've ran is the coolant hose between the module and tank, and the return line from the module to the tank (finished that this evening). Right now it follows the same path as the first coolant hose shown in the pics.
Once I'm done, I'll bundle them all together and wrap them with insulation tape. I might need a bit more coolant hose - won't know for sure until I make the long run for the coolant return back to the motor (it'll follow the same path), but if I need extra, I should be able to get it from Autozone or Advance Auto.
Thanks!
Thanks!
Thanks Marv - 22" should work...
Marv,
your tank drain looks very elaborate...I put the drain on my tank to drain water that may accumulate over time...have only used it once for that. I would use a barbed fitting - 1/4" is plenty and a cmall 1/4 clear hose. come straight out of the tank with the fitting, run the hose 3-4 inches then drill a hole through the bed - or in your case you ran your other hoses through that same corner so run your drain hose out that to the bottom and get a small pet**** valve to put on the end of the tube. let it hang there and leave it. When you want to drain a 1/2 gallon to see if theres water in the tank a year from now, all you do is park the truck over night with that corner of the tank being the lowest point and water will migrate to that point and the next morning you can drain off a quart or 2 and your done.
Discussion Starter · #18 ·
Marv,
Yeah it probably is a bit more than I'll need. I actually mocked that up before I set the tank in the bed. Once I got it in there, I quickly realized it wouldn't work.
Actually, I had the same idea you mentioned - using a barb fitting in the tank and then putting the pet**** valve below the bed, zip-tied up out of the way.
The main reason I considered that was after our discussion on the phone Friday about your issues draining your old tank so you could install the new one. I doubt I'll ever need to drain the vegi oil out, but figured now would be the time to put in the necessary plumbing if I'm going to.
I'm gonna give it some more thought, but I imagine I'll go with the simple 1/4" line and a small valve down below. Should be plenty for draining the water from the tank.
Thanks!
for a few bucks you can get a transfer pump if you ever need to empty the tank - not much chance you will ever need to unless you trade trucks and want to pull the tank. Draining even 20 gallons through this 1/4" line is slow but its doable...takes a couple hours to drain that much.
the petcoc k i used is here
Part number 46555K25
Discussion Starter · #20 ·
That's a good thought as well...never considered the transfer pump.
Thanks for the PN too...I'll look into that. :thumb:
1 - 20 of 285 Posts
