1 - 16 of 16 Posts
I have some things to say about my truck. First off the fuel gauge pisses me off. The low fuel light never comes on and it gets stuck below empty every once in awhile. It also gets 11 MPG going 70 mph on the freeway. The door sqeeks, every time I roll the passanger window down it sweeks also, rear window gets binded and is a pain to open/close, the pin hole on the trailer hitch is ovaling. It does 0-60 in 12.5 Sec. It doesn't stop to well. Tranny slips. Everytime I put the truck in reverse it slams into to reverse (feels like getting rearended) and then it delays when putting it into drive and when it goes into gear it makes a clunk grinding noise.
Stupidity pisses me off
Hey man you got a 6.0, :dunno: what else is there to say :icon_ford:
Wish it had a 7.3.
Hey we have plenty of problems also. At least you have the benefit of them all happening at once so you know whats going on. Everytime I get something done, something else happens. But I guess thats just trucks that are used for more than home decorations :dunno:
You couldn pay me to get rid of my 6.0.... He didn say there was anythin wrong with the motor:dunno:.... Sounds like you got a lemon.... Why not sell it???
Already got the truck the way I like it. If I were to sell it I wouldn't be able to get another PSD. This one came at the right time when I got it. I'm in a battle with Ford to try and get the tranny fixed.
Well I hope you get it all figured out.. Cuz you got a sharp truck.... Hang in there
First - sorry you are having problems.
Second, the torqshift is a VERY reliable transmission - for most they are providing excellent reliability.
Last - these injectors do not like low fuel pressure. If you are continually running to empty (or near empty), you are taking unnecessary risks and the repair costs can be huge. From what you have said, I assume that the fuel gage works properly until it gets below empty. If it works well until you get to the low level - why let it get that low??
There is a known issue that I haven't read about recently. The issue is problems w/ your fuel gage if you fill up with the truck running. It eventually resets. Won't have the problem if fueling w/ engine off. Don't know if this is your issue, but based on a previous post, it seems that this was happening to you.
12.5 seconds for 0-60 isn't that bad for a stock 8000lb + truck. My truck is running well and does it at 12 seconds - maybe a tad under. Do you have any mods? What codes are you getting on your transmission?
Didn't you have a programmer in the past? Also, did you recal the speedo for having 35's?
Try lubricating the door and windows...
Odd that the hole in the trailer hitch is ovaling. Shouldn't be too hard to reinforce/swap out though.
It's a 7500lb truck, not a porsche
As for the tranny: Most people like the torqshift, so you might just have some sort of lemon/abused (see programmer question)
Discussion Starter · #10 ·
The fuel gauge isn't consistant some days right below a 1/4 the truck will take 23 gallons and some days it will take 27. One time it was on an 1/8 running fine and then I put 5 gallons in it and it took awhile to start and ran ruff.
It did have a programmer but hasn't been on for 10K miles and still has all of the same problems. The truck had 2 tranny's when it was completly stock. The programmer didn't cause any new problems it just gave the truck more power and thats it. No one has an opinion on the 11 MPG.
Dunno. Either there is something fishy about the truck or you really beat the piss out of it. Has it ever been in a wreck? Do you tow ALL the time?
have you tried cleaning the egr valve? that might help your performance and milage out a ton!
as far as the rest of it goes I would take the truck down to ford with your lawyer and say Im coming to pick it up in one week and I want it FIXXED!!!!!!!!!!!!!!
Discussion Starter · #14 ·
IIRC from another thread, aren't you on your 4th or 5th 5R110 replacement?
5th
Don't beat the piss out of it but drive it like a 6.0 should be driven*. I'm the first owner and it's never been wrecked. It tows maybe 400 miles a month.
* My definition on how a 6.0 should be driven. Don't drive like a grandma but don't drive it like a spoiled teenager. Cruise it and on a good straight open it up get it hot and cleaned out then back to cruising.
1 - 16 of 16 Posts
