Do it yourself, we're here to help with what we can...
First thing you want to do is to be able to Scan for Codes and Monitor Sensors yourself. You have an '01, whos electrics (most importantly here it's PCM (computers) programming) can be either as an '02 or a 2000. Look at the dash cluster, if you have a digital OD and a Trans Temp Gauge in it then treat it as an '02. If not as a 2000. Also, if not, you should be able to see the Tach needle bounce-up a tiny bit while cranking on the Starter to know that the CPS is doing its job ('02's need the scanner to see that cranking rpm)
In any NoStart condition we want to monitor these 4 Important parameters while trying to start;
ICP Pressure ~ (in PSI plz, the PCM requires something over 500 before it will trigger the IDM to fire the injectors)
IPR% ~ (shows how Hard the system is having to work to make that ICP pressure)
CRANKING RPM ~ (PCM requires above 100rpm ~ 150 is typical)
CRANKING Voltage ~ (in an '02 PCM requires it not drop below 9v, in a 2000 not below 10v)
My Usual Scanner Advice;
If you're gonna keep & maintain the truck yourself I strongly suggest you get access to the special scanner software you need to do it.
To retrieve most of the codes you'll need to help and even do
some testing look at the FORscan Lite or TorqueApp (you add an Android device and Blue Tooth Adapter for @ $30) OR the Windoze version with a USB adapter. I like this one for BT Android ->
http://www.amazon.com/BAFX-Products-34t5-Bluetooth-Android/dp/B005NLQAHS/
Just a few years ago you needed to buy a professional scan tool because our trucks need to have a scanner with a Library containing both the Ford Proprietary AND the Diesel Specific codes in it. Add to that, our trucks are Not, specifically, OBD-II so the Generic scanners the Auto Parts Stores have are of little use to us. But today there are some very good App based tools, that are close to what the pro tools do, for fraction of the cost.
How To: Super Duty Diagnosis on the Cheap! This will be a multi-part write-up, covering how to diagnose, monitor, and run tests on Ford Super Duty Trucks, focusing on the Ford 7.3L Super Duty as that is the truck that I own, but these tools work for all Super Duty Trucks. Warning: Some...
www.powerstroke.org
