SWEET!!!
Don't rush! take your time! Do the work the right way!
Some extra help
After you have the turbo in and the drain plug attached, put some engine oil in the turbo and spin it a few times so it will not be having a "dry start".
Same with installing the new injectors(but not entirely)
Before you work on the injectors, have a good amount of diesel kleen and/or 2-stroke oil, preferably 2-stroke for the increased lubricity, and put some drive time so that it gets to the entire system.
And depending on how many miles is on this oil change, and if you do not have this already, change to syn oil before the work so that there is less ware and tare on the first start up.
